Carb for TV175
Carb for TV175
Postby NorthernJordan » Sat Aug 25, 2018 7:35 pm
What's the best car for a standard TV175?
This is an early one and I've heard they aren't the best. Will be used with an air box and a scootopia clubman.
NorthernJordan
Re: Carb for TV175
Postby Cgt75b » Sat Aug 25, 2018 9:41 pm
Are you putting a standard carb on it?
Re: Carb for TV175
Postby EddieStone » Wed Aug 29, 2018 9:14 am
I thought these ran 20mm carbs?
EddieStone
Re: Carb for TV175
Postby Scooter Paul » Wed Aug 29, 2018 9:31 am
Series 1, 2 or 3? Series 3 definitely had a 20mm SH1/20. If I was building up a bike and I wanted to keep it semi standard I’d be inclined to go with a Scootopia 22mm on a GP 150 manifold through a standard air box. 25mm Delortos work well but I’ve always had to open up the standard air box but I’d also be inclined to try the MB big flow airbox.
Scooter Paul
