Loose carb.
Loose carb.
Postby Scooter Paul » Sun Apr 23, 2017 11:37 am
I've never had this before. Genuine Italian GP200 manifold and genuine SH2/22 carb. Carb came loose and will not tighten up. Nylon carb sleeve looks fine but manifold stub looks like it's been fretting away reducing the diameter. I'm going to try a new manifold tomorrow. Let's see.
Paul.
Scooter Paul
Re: Loose carb.
Postby hullygully » Sun Apr 23, 2017 12:27 pm
if anything the plastic would wear first :shock:
Re: Loose carb.
Postby Scooter Paul » Sun Apr 23, 2017 2:48 pm
hullygully wrote:if anything the plastic would wear first :shock:
I agree but parts came from different sources. I could well have thought it was tight when it wasn't.
Scooter Paul
Re: Loose carb.
Postby St George » Sun Apr 23, 2017 3:01 pm
Had this before, the nylon reduces in size due to over tightening, unlike rubber does not expand.
St George
Re: Loose carb.
Postby Scooter Paul » Sun Apr 23, 2017 3:41 pm
St George wrote:Had this before, the nylon reduces in size due to over tightening, unlike rubber does not expand.
I forgot to mention, it's even looser when mated to a brand new Jetex. I'm convinced the alloy has worn away.
Scooter Paul
Re: Loose carb.
Postby St George » Sun Apr 23, 2017 4:22 pm
I suspect that Jetex manifolds are slightly different in size to our Italian versions otherwise people would not be after Italian GP 200 manifolds.
St George
Re: Loose carb.
Postby coaster » Sun Apr 23, 2017 5:30 pm
The nylons do wear but so do the manifolds. If fitting a new nylon doesn't cure it you will need a new manifold. This was a common problem back in the 60s/70's :(
Re: Loose carb.
Postby Scooter Paul » Mon Apr 24, 2017 1:24 pm
New manifold from Allstyles. Now a tight fit. The old, original, manifold was definitely worn.
Scooter Paul
Re: Loose carb.
Postby St George » Mon Apr 24, 2017 5:28 pm
Learn every day. Glad it's sorted.
St George
Re: Loose carb.
Postby Scooter Paul » Mon Apr 24, 2017 6:46 pm
St George wrote:Learn every day. Glad it's sorted.
Thanks. Yep, I've never seen the like before either.
Paul.
Scooter Paul
Re: Loose carb.
Postby rossclark » Wed Aug 01, 2018 12:00 am
coaster wrote:The nylons do wear but so do the manifolds. If fitting a new nylon doesn't cure it you will need a new manifold. This was a common problem back in the 60s/70's :(
Resurrecting this as I've had a problem recently with the carb appearing tight but over a few miles it seems to rotate clockwise on the manifold resulting in the throttle cable becoming tight and lifting the slide.
Any tips on changing the plastic bushes?
Re: Loose carb.
Postby Knowledge » Wed Aug 01, 2018 1:41 pm
Ross,
The conclusion of the above thread was that the most likely cause of the loose carb was the worn manifold.
Although people don't believe this, it is the ali manifold that wears out before the nylon insert. I have witnessed this many times.
Investigate the cost of a new manifold. You might be pleasantly surprised.
martin
Re: Loose carb.
Postby rossclark » Wed Aug 01, 2018 4:44 pm
Thanks, I may just replace both as a matter of course.
Re: Loose carb.
Postby rossclark » Sun Aug 05, 2018 8:55 pm
Just to answer my original question, if you remove the slide there are two points where you can get a small thin punch against the bush and gently knock it out, but it's unlikely to come out without some damage to the plastic. Once it was out I opened up the slots on the carb which were almost completely closed up.
Fitting the new bush is another game altogether...
In the end I got it in by squeezing it in the jaws of the workmate, it went quite a frightening shape before it popped in.
It seems to be very solid on the new manifold whereas the old one was distinctly wobbly until tightened. I just hope I don't have to take it off again too soon...
Return to Carburettors
Users browsing this forum: No registered users and 3 guests
