Forks dimension
Forks dimension
Postby garynonnah » Sat Sep 13, 2014 6:22 pm
HI all
Can anyone tell me..... I have two sets of forks, original std Indian gp, and a ser 3? set upgraded to take dampers.
Q? The dimension between the fork links is 5mm wider with upgraded forks.
garynonnah
Re: Forks dimension
Postby Wack » Sun Sep 14, 2014 7:12 pm
Measure between the fork legs between the link welded on washers. It should measure roughly 130 mm if I remember rightly.
Re: Forks dimension
Postby garynonnah » Sun Sep 14, 2014 9:32 pm
thanks....gp forks are 130mm, but the refurb forks are 135mm, not sure if i could use shim washers to take up difference.
garynonnah
Users browsing this forum: No registered users and 22 guests
