Mori63 wrote:The exhaust manifold is the same as a TS1 but the studs are 8mm ,I've got this kit but haven't quite got it sorted yet it's got a flat spot between 3500-4500 but once it's through that and in the power it goes mad ....
Mori63 wrote:Hi, at the moment I'm running a GP200 gearbox with 19 x 46sprockets ,a JL 4 ,a 30mm PHBH with a 40mm slide ,av268,x13 at 2 and half clips,62 pilot and 132 main through a filter.i had it dyno'd and they told me it would benefit from fitting a different pipe .so this weekends job is fitting a franspeed race.
Users browsing this forum: Majestic-12 [Bot] and 13 guests
