broken Needle
broken Needle
Postby Norrie Bodge » Mon May 28, 2018 4:04 pm
had a lucky one on the way home from kelso yestea
just pulled in from the outside lane doin 70ish when i lost all power, manage to coast into a layby
& on checking things out found this, luckily the broken off bit & circlip where in the slide, & i had a spare needle in me toolbag to get me home!
has anyone any any good ideas to prevent this happening again?
maybe a diff type of circlip used??
Norrie Bodge
Re: broken Needle
Postby St George » Mon May 28, 2018 5:38 pm
Clearly metal fatigue, buy another make.
St George
Re: broken Needle
Postby Mel K » Mon May 28, 2018 10:04 pm
Try and figure how many miles you’ve done on that needle and change it as a matter of course sooner in future?
Mel K
Re: broken Needle
Postby hullygully » Wed May 30, 2018 10:42 am
THAT CIRCLIP SHOULD HAVE WORN WELL BEFORE THE NEEDLE!!!
Re: broken Needle
Postby mcbrid » Sat Jun 02, 2018 9:49 am
I've had two needles almost go like this now and did 2500 miles between fixing the first problem and the latest
The needles/circlips were bought from Dellorto UK so should be OK but the circlips in both cases had worn through and made the needle thin where the groove is
In my case the circlip then dropped down the needle and was still lifting it but by jamming on the shaft causing all kinds of running issues.
Something is not right here - as a matter of interest it was a K24 needle
Check your needles folks!
mcbrid
Re: broken Needle
Postby Mel K » Sat Jun 02, 2018 5:59 pm
There’s a brass insert on the slide that you should punch in so it locks the needle in position, stops the needle moving around and prolongs the life of the clip end but still should be checked regularly . A new needle and new needle jet works wonders .
Mel K
Re: broken Needle
Postby mcbrid » Sat Jun 02, 2018 11:37 pm
Mel K wrote:There’s a brass insert on the slide that you should punch in so it locks the needle in position, stops the needle moving around and prolongs the life of the clip end but still should be checked regularly . A new needle and new needle jet works wonders .
Is that reversible then?
New jet was fitted same time as needle BTW
mcbrid
Re: broken Needle
Postby Mel K » Sun Jun 03, 2018 6:17 am
Possibly Have to persuade the needle back out with a persuader , when you need to .
Mel K
Re: broken Needle
Postby Norrie Bodge » Sun Jun 03, 2018 7:28 am
Mel K wrote:Possibly Have to persuade the needle back out with a persuader , when you need to .
i got all this in PM a few days ago, & to add regarding changing needle...
Best way is to grip the needle in a small vice using strips of rubber then twist and push the slide down careful not to bend it.
ive got a new needle & atomiser ordered
Norrie Bodge
Re: broken Needle
Postby Mel K » Sun Jun 03, 2018 8:56 am
CP? Solid advice. Best of luck 8-)
Mel K
Return to Carburettors
Users browsing this forum: Bettagetabrettabolti and 3 guests
