ToBoldlyGo wrote:Couldn't you fit some sort of spacer between the manifold and carb to bring it out a few mls?
bike grim wrote:Does a normal Steel cowl fit? What has Chiselspeed used? Or is it the PHBH carb thats the difference ?
corrado wrote:The rubber on the manifold looks like it can be reveresed but it'll put the carb at an angle. As I've only got an unmounted kit I can't work out if there's a right and a wrong way to fit the rubber. It looks right with the carb flat, as pictured, but may be ok with it turned around so that it gives more clearance. Most carbs end up fitted at an angle so it may not be an issue.
What about frame clearance? It may be an issue.
Raveydavey wrote: Its all sealed and leak tested. NOt having ever had someone build a motor for me before I'm reluctant (at this point) to start dismantling.
HxPaul wrote:Use this https://www.ebay.co.uk/itm/9-Sheets-Car ... SwIFtaL0gT or similar,remove carb,cut to shape and stick on the cylinder cowl,re-fit carb.
Psychedelicropcircle wrote:If you have the measurements for the bolt holes to connect with the reed block I have a spacer which will solve your problems, if & I say if the measurements are the same.
Scott.
Lammer205 wrote:Hi,
if you rotated the carb manifold rubber 180 degrees doe's that lift it away from the cowling it's just that looking at the third photo the carb doe's look to be angled downward?? Or is it just the carbon cowling? anyways best of luck with the motor it will be good to hear some more road ridden reports.
Lammer205
Users browsing this forum: Google [Bot] and 21 guests
