GT 240 / GT casing
Re: GT 240 / GT casing
Postby modster79 » Wed Jan 24, 2018 8:44 am
Had a message today for a recall on my GT240 cylinder, Rich has identified some of the bores are two tight and are at risk of seizing. Brilliant now got to strip down and send cylinder back for honing, not amused.
modster79
Postby Covboy » Wed Jan 24, 2018 8:58 am
Thanks for letting me know - I was planning to fire mine up for the first time this weekend.. ill call him....
Postby Scooterdude » Wed Jan 24, 2018 11:52 am
modster79 wrote:Had a message today for a recall on my GT240 cylinder, Rich has identified some of the bores are two tight and are at risk of seizing. Brilliant now got to strip down and send cylinder back for honing, not amused.
Look on the bright side, you’ll not only get the bore done you should also get a new piston and have piece of mind everything is right and in tolerance.
Scooterdude
Postby Seamus murphy » Wed Jan 24, 2018 12:23 pm
Cant fault eden bakewell for his proactive response he spent sat driving round the country collecting barrels to be re worked
Seamus murphy
Postby burnside » Wed Jan 24, 2018 1:39 pm
I think I would prefer to be informed off a recall and it getting sorted out than denying there is an issue and blaming the quality of the build like some have in recent times
burnside
Postby Covboy » Wed Jan 24, 2018 7:46 pm
Hi
Rich has just collected mine - will be back in a couple of days..
Only 240cc are affected and I gather the affected batch owners have been / are being contacted.
It's a hone to remove 1 thou which is .02mm.
Postby modster79 » Thu Jan 25, 2018 8:59 am
Your right on the bore least I will know it’s correct, no new piston just honing of cylinder.
modster79
Postby Seamus murphy » Sun Jan 28, 2018 4:17 pm
Barrel collected last sun by eden bakewell and returned today sun cant fault that for sorting out a pottential problem.
Seamus murphy
Postby Scooterlam » Sun Jan 28, 2018 11:16 pm
do you have to run in again after a hone?
Scooterlam
Postby coaster » Sun Jan 28, 2018 11:59 pm
Scooterlam wrote:do you have to run in again after a hone?
I would have though so as the bore will have some roughness from the hone
Postby Simon_T » Sun Apr 15, 2018 9:32 pm
coaster wrote:I have one of the GT240 kits fitted to a TV200 case. Very pleased with it so far, completed the build just before leaving for Adria with only 200 miles completed. Had it set up on a Dyno then finished running it in on the way down. With a bgm pipe fitted it pulls from 30 mph through to 65mph in 4th with no power band up hill down dale loaded with gear for / weeks camping. If you want to run a filter then go for the left and hand inlet manifold option
Coaster what carb you using on that setup please.
Regards
Simon_T
Postby coaster » Sun Apr 15, 2018 10:13 pm
30 PHBH on the kick start side.
Postby coaster » Sun Apr 15, 2018 10:14 pm
PHBH on Kick Start side
Postby TS1-200 » Tue Apr 17, 2018 9:06 pm
Interesting thread, just built a GT240 only run it up and down the road at the moment, so no real conclusions, running a JL3 exhaust (as it was handy)30mm Delly on the kickstart side,but using a 145 MJ on Edens advice, but will do a few hundred miles to loosen up and then get it set up on a dyno, is the manifold the same for right and left carb fixing ? I do prefer right side as there is more room for the carb, unfortunately doesn`t seem too much room for a filter
TS1-200
Postby Toddy » Tue Apr 17, 2018 9:42 pm
TS1-200 wrote:Interesting thread, just built a GT240 only run it up and down the road at the moment, so no real conclusions, running a JL3 exhaust (as it was handy)30mm Delly on the kickstart side,but using a 145 MJ on Edens advice, but will do a few hundred miles to loosen up and then get it set up on a dyno, is the manifold the same for right and left carb fixing ? I do prefer right side as there is more room for the carb, unfortunately doesn`t seem too much room for a filter
I think they are different for left and right exit
