Rear brake cable routing
Postby Tractorman » Fri Nov 17, 2017 1:36 pm
Did I see a post sometime ago regarding the routing of the rear brake cable that said it should go between the plug and the frame? I tried routing this way but it seems to be very close to the plug cap.
Re: Rear brake cable routing
Postby coaster » Fri Nov 17, 2017 1:56 pm
I believe that is correct but whatever you do, don't route it over the top of the engine mount, I did that and it worked fine until I loaded up for Adria and found that the brake was pulling on :oops:
Strangely, that detail has been missed in both versions of Sticky's book :?
Postby Tractorman » Fri Nov 17, 2017 2:33 pm
coaster wrote:I believe that is correct but whatever you do, don't route it over the top of the engine mount, I did that and it worked fine until I loaded up for Adria and found that the brake was pulling on :oops:
That's the first thing I did was search through the Book.
Postby gaz_powell » Fri Nov 17, 2017 2:39 pm
Drop Sticky a line - he`s currently working on Rev 3
Postby roli150lam » Fri Nov 17, 2017 5:14 pm
It was an article in scootering.wtitten by Stu.Owen
August issue p.115
roli150lam
Postby Tractorman » Fri Nov 17, 2017 7:37 pm
Thanks, Roli I knew I'd seen it somewhere.
Postby dickie » Fri Nov 17, 2017 10:19 pm
I think the rebuild blog on lcgb home page by Paul slack covers this.
Postby Tractorman » Sat Nov 18, 2017 10:05 am
dickie wrote:I think the rebuild blog on lcgb home page by Paul slack covers this.
I searched through it but could not find it, where is it, please?
Postby dickie » Sat Nov 18, 2017 2:49 pm
It's toward the end of this page. http://lambrettarestorations.blogspot.co.uk/2011/10/installing-cables-engine-end-only.html?m=0
This blog plus stickys have been incredible for me. Working in isolation and not having a lambretta since 86 (ld125 in boxes) does not make an expert but I've been able to do pretty much everything from just those two!
Postby Tractorman » Sat Nov 18, 2017 6:21 pm
Thanks for that, I note he routes the cable to the right of the plug. I have always done it this but thought I would try the other but as I posted it close to the plug cap.
Postby Warkton Tornado No.1 » Fri Dec 08, 2017 11:40 pm
Tractorman wrote:Did I see a post sometime ago regarding the routing of the rear brake cable that said it should go between the plug and the frame? I tried routing this way but it seems to be very close to the plug cap.
As since mentioned in the responses, it appeared in Scootering.
With an open mind, considering I'd never known of the routing mentioned within the article, I tried it.....
I soon reverted to the 'norm' because plug cap & plug were painstakingly difficult to remove & replace, but that may be just the case for me.
However, I would go so far as to suggest that the cable is likely to 'work' the plug cap off in no time! Perhaps that was the reason that in the sixties/seventies there were many riders reported the detachment of their plug cap. :?
Postby Danbretta » Sat Dec 09, 2017 8:31 pm
My import came with this routing (if it helps).
Seems to be ok not sure if it's the correct way.
Danbretta
Postby Warkton Tornado No.1 » Mon Dec 11, 2017 7:14 pm
Danbretta wrote:My import came with this routing (if it helps).
That is the way that 'works' for me & I've never seen any other than when I briefly tried 'the other way' ;)
