Gori 200 kit
Gori 200 kit
Postby serveta1 » Sun Oct 15, 2017 9:08 pm
Please could someone confirm if the inlet stud spacing on this kit is the same as a normal 200 cylinder or that of a 150?
serveta1
Re: Gori 200 kit
Postby MickYork » Mon Oct 16, 2017 7:46 am
Gori do produce a 200 kit for the small block and I am not aware that they do one for the large block........if that helps. Cam-Lam and Rimini have more info'
Re: Gori 200 kit
Postby serveta1 » Mon Oct 16, 2017 8:50 am
Sorry, I meant the inlet stud spacing on the small block 200 kit.
serveta1
Re: Gori 200 kit
Postby hullygully » Mon Oct 16, 2017 6:31 pm
the small block Gori 200 kit's inlet manifold has 200c/c stud spacings, I can confirm 8-)
plus, beware that the barrel's being top & tailed, so also be warey when doin squish clearances, think I used RB20 head gaskets totalling 2.5mm!!!!!!!!!!! :o
Re: Gori 200 kit
Postby serveta1 » Mon Oct 16, 2017 8:00 pm
Thanks, was that a 2.5 head gasket when running 58x107 crank?
serveta1
Re: Gori 200 kit
Postby hullygully » Tue Oct 17, 2017 6:33 pm
it was yes, I changed their head after several piston / head coming togethers, I ended up using a gt porcupine one, but still be carefull
Re: Gori 200 kit
Postby serveta1 » Wed Oct 18, 2017 8:42 pm
Cheers mate, I’ll double check the squish
serveta1
Users browsing this forum: Google [Bot] and 8 guests
