amal mk1 mounting on a 150 barrell
Postby neil64 » Tue Sep 12, 2017 5:37 pm
hi ,
i have aqiured an amal mk1 carb all in good order that i would like to run on a 150 cylinder . any ideas re fixing to manifold as the carb is the old 2 screw mounting .
any help would be great .
neil64
Re: amal mk1 mounting on a 150 barrell
Postby gerryjunior » Tue Sep 12, 2017 9:40 pm
youll need a manifold made for the amal mk 1 , a few people mead them scootamobile , royspeed, rimini etc, hard to find for a 150 , most were made for 175 or 200, I had a few ill check if I have any left.. if not ill post a pic of what your looking for,
gerryjunior
Postby tim_mason » Wed Sep 13, 2017 9:49 am
I had a stub that fitted onto a standard manifold, i will have look later.
tim_mason
Postby rossclark » Wed Sep 13, 2017 9:16 pm
What's the distance between the centres?
Mito Lambretta did a flange mount manifold with horizontal flange holes. It's 60mm between the centres.
Postby Dimitrios_231 » Wed Sep 13, 2017 9:20 pm
Two inches for an amal (centre to centre).
I have a stub adapter that can be clamped on a 38mm O/D manifold.
Dimitrios_231
Postby rossclark » Wed Sep 13, 2017 9:22 pm
Dimitrios_231 wrote:Two inches for an amal (centre to centre).
Haha I almost said I thought it would be imperial...
Postby Dimitrios_231 » Wed Sep 13, 2017 9:24 pm
50.8mm for our metric friends
Dimitrios_231
Postby coaster » Wed Sep 13, 2017 10:48 pm
British bikes suck as BSA, Triumph, Norton used Amals and some had an ally spacer block between the barrel and the carb. They should be fairly easy to source and could be welded to a standard manifold.
http://www.ebay.co.uk/itm/TRIUMPH-DAYTO ... 3641.l6368
