SR185 kit
SR185 kit
Postby jonno » Sun Aug 20, 2017 7:49 pm
Just stripping down an engine thats been sitting for several years,fitted with an SR 185 kit.Measured the ring gap and its well over 0.6mm even though its not done 1000 miles yet. Anyone know what the recommended gap is for these kits and where I can get more rings,in case theyve been filed too much? Sr out of stock
jonno
Re: SR185 kit
Postby Knowledge » Sun Aug 20, 2017 9:08 pm
Some of these kits had a rather soft cast-iron core. The bore can wear excessively, so it might not be worn rings, but worn bore. Check the bore to piston clearance.
Re: SR185 kit
Postby jonno » Mon Aug 21, 2017 2:40 pm
Bore clearance is 0.1 ish.The ring gap is about a 1 mm. Doing a deglaze as well how do you get the cross hatching ?All I seem to get are loops.Thats slow speed but quick up and down the barrel.
jonno
Re: SR185 kit
Postby ULC Soulagent » Wed Aug 23, 2017 5:27 pm
jonno wrote:Bore clearance is 0.1 ish.The ring gap is about a 1 mm. Doing a deglaze as well how do you get the cross hatching ?All I seem to get are loops.Thats slow speed but quick up and down the barrel.
I use fine grade honing tool @ medium speed going at a moderate up n down speed. Lube is good old wd40
ULC Soulagent
Users browsing this forum: No registered users and 2 guests
