Jetting for 175, 25mm PHBL & clubman
Postby Knowledge » Mon Jun 02, 2014 10:53 pm
Suggestions please.
(BOK)
Re: Jetting for 175, 25mm PHBL & clubman
Postby nsaints » Wed Jun 04, 2014 3:54 pm
Does a GT186 count - OK it does
Through a modified air box (neck cut out, no holes), MB Gauze filter, AF Clubman
Setup via dyno
Main Jet 105
Needle D22 3rd (from Bottom)
Needle Jet AQ266
Slide 40
Pilot 52
Choke 70
nsaints
Postby corrado » Sat Jun 07, 2014 1:49 pm
Just done one for a similar 150 set up ...
D22, 2nd clip from top.
102 main.
50 pilot.
40 slide.
AQ264.
They come factory fitted with ..
D22
102 main.
70 pilot.
40 Slide
AQ266
So apart from the pilot they're in the ball park out of the box.
corrado
Return to Carburettors
Users browsing this forum: Bing [Bot] and 2 guests
