Meceur rear sprocket
Postby rossclark » Tue Jun 27, 2017 9:50 pm
Anyone know if these are hardened for bearings or if they're bush type?
Re: Meceur rear sprocket
Postby daniel whiteley » Wed Jun 28, 2017 10:15 am
I'm sure I read somewhere that you need to use a bush but don't quote me on that
daniel whiteley
Postby rossclark » Wed Jun 28, 2017 11:05 am
I think it looks like the probable safe option is to use a bush if you're unsure.
Postby rossclark » Fri Jul 07, 2017 8:38 pm
For info, I found that none of the standard type clutch spiders that I had would protrude through the back of this sprocket properly, it would have needed machining but I had an Atomic one under the bench which worked fine.
Postby dickie » Fri Jul 07, 2017 9:09 pm
rossclark wrote:Anyone know if these are hardened for bearings or if they're bush type?
I've got one and rightly or wrongly was told it was Bush only. Not hardened.
I had to grind it by maybe 50 microns to get it to spin freely. Used an oil stone; easy job and maybe 10 minutes.
Users browsing this forum: No registered users and 9 guests
