Mugello 198 and Gori
Postby Wack » Mon Jun 12, 2017 9:32 pm
A mate has tried to fit a Gori box pipe to a v4 Mugello kit but although the box fits the casing it's miles out on the u pipe. Has anyone else had this problem?
Re: Mugello 198 and Gori
Postby Scooterdude » Mon Jun 12, 2017 9:40 pm
http://www.scooterotica.org/forum/viewt ... 30#p291995
See here. Worst thing I ever bought, cheaply and poorly made and finished and on top of that not a hope in hell of getting it to fit, read from bottom of page 3.
Scooterdude
Postby Toddy » Tue Jun 13, 2017 6:08 am
I belive the mugellos have a slightly different exhaust angle there is a different swans neck bracket for the BGM clubman available .
Postby Simon ELC » Tue Jun 13, 2017 7:13 am
I fitted the same pipe and barrel combo to a mates scoot.
The U bend fitted perfectly. However, the tail pipe was way off and needed significant heating and bending.
Simon ELC
Postby Wack » Tue Jun 13, 2017 7:25 am
Thanks for the info everyone, looks like it's a common problem that can only be sorted by cutting and re-welding.
Postby Scooterdude » Tue Jun 13, 2017 7:43 am
My Scootopia clubman fitted my iron 175 conversion perfectly as it did the Mugello so nothing had changed with the angle of the cylinder/port arrangement they were identical.
Overpriced lump of noisy scrap imo.
Scooterdude
Postby Toddy » Tue Jun 13, 2017 12:19 pm
Scooterdude wrote:My Scootopia clubman fitted my iron 175 conversion perfectly as it did the Mugello so nothing had changed with the angle of the cylinder/port arrangement they were identical.
Wonder why BGM/MB changed the Swans neck bracket then for Mugellos then ?
Postby Scooterdude » Tue Jun 13, 2017 1:17 pm
Well mine is an early one with just the four studs as opposed to the later ones with 7. Point I'm trying to make is it Dident fit my Mugello so therefore it wouldent have fitted the iron 175, or any other cylinder for that matter either as they were identical.
Scootopia clubman fits both, I don't see Scootopia offering an alternative down pipe for Mugello do you? :roll:
Scooterdude
Postby Delboyli150 » Wed Jun 14, 2017 6:18 pm
Hi had exactly the same problem down pipe fitted fine but the bracket which goes on the side casing was 2 inches out by the rear tyre. Took everything off and slowly heated and bend until fits, absolute Fr%%^&g nightmare! Do everything loose then tighten up As previous thread mentioned I brought some long nuts to wire up but these cannot fit.
To be fair I did ring up the shop where I brought it ( The one in St Ives), and they said send it back, but I am too stubborn and had to fit it!
I hope there is no stress pressure on the can end otherwise it will crack.
But must admit looks nice and that loud my missus can put the kettle on when I am 2 miles away!
Delboyli150
Users browsing this forum: Solid Air and 1 guest
