slight clutch cable rub
Postby Andie » Fri Jun 02, 2017 9:38 am
My clutch failed at lights last night - on inspection the outer was completely severed and the inner down to one strand. I guess it had been rubbing...
Was only a few miles from home so managed to get back and fit new cable
I run the cable coming through the headset correctly from the RHS, through the clip and over the rod to enter the clutch lever housing ahead of the rod.
I wouldn't want this happening again - is there something I might be missing?
Thanks - Andrew
Andie
Re: slight clutch cable rub
Postby landybretta » Fri Jun 02, 2017 10:14 am
It could be that the outer cable was pulled too tight causing it to rub on the shaft. I always coat both the shaft and the outer cable with grease where they may come into contact. There should be a loop as per the picture below.
landybretta
Postby Andie » Fri Jun 02, 2017 2:07 pm
Thanks Landy.
I've kept it loose and greased the shaft...
and tested at various positions.
I'll see how it goes and check it in a weeks time. I recall reading somewhere that people dremmel the hole bigger, but I thought that was for the busy throttle side where the LX and cable are fighting.
Andie
Postby Fast n Furious » Fri Jun 02, 2017 6:01 pm
You can find some good advice in Sticky's book with regard to fettling the headset casting to give your outer cable an easier time. Well worth doing.
Postby Wack » Fri Jun 02, 2017 8:24 pm
I agree with the Dremel mod,but also note that the new nylon lined cables are thicker and less plyable so are more likely to chafe especially going into 4 th gear.
Postby Andie » Sat Jun 03, 2017 6:23 pm
Thanks chaps
Andie
Users browsing this forum: Google [Bot] and 70 guests
