Warkton Tornado No.1 wrote:...............However, what I do know is that the ‘science’ of removable wheels that fit a hub is not unique to Lambretta or even V*spa. I can’t think of a car that doesn’t centre its wheels on the hub to take the load because those automotive engineers are well aware of the loads, particularly shock loads that can cause ‘slippage’ (as they say @ Land Rover) That’s why even ‘amateur’ car owners that adapt wheels of one marque to another use special centering rings to take the load through to the hub in the case of oversize wheel bores...
coaster wrote:Warkton Tornado No.1 wrote:...............However, what I do know is that the ‘science’ of removable wheels that fit a hub is not unique to Lambretta or even V*spa. I can’t think of a car that doesn’t centre its wheels on the hub to take the load because those automotive engineers are well aware of the loads, particularly shock loads that can cause ‘slippage’ (as they say @ Land Rover) That’s why even ‘amateur’ car owners that adapt wheels of one marque to another use special centering rings to take the load through to the hub in the case of oversize wheel bores...
I can't think of any where the wheel centre is a tight fit on the boss on the hub IF there is always a boss? Car wheels have a dished (sometimes raised) seat for the wheel nut to 'centre' the wheel. That and the Clamping Force imposed on the wheel rim against the hub will be what stops any movement. Some wheel nuts have straight shanks that serve the same purpose
coaster wrote:That's a very well reasoned response from AF.
Sticky wrote:You won't get any disagreement from me on this Warkton. I'd much prefer the wheel to be centralised and locate on the hub than just to be held by the four studs.
