Some advice please, best rear hub bearing suggestions?
davet wrote:I've got a photo to show you revealing that the god's have been with me recently. Not so long ago I was doing 8600 revs in fourth on M58 (17x46 pacemaker). I decide to check over the scooter before the Euro. Casing off, give gears a prod and plenty of wiggling and side movement going on. So I take out the gearbox, well worn by the way and find this:
davet wrote:Fitted correctly and always used recommended oil, which was changed regularly. The bearing's done about 15k. Will be sending it to MB to let them know. I hope it's sent back to manufacturer for a look see. I ain't blaming MB coz the problem lies somewhere else.
Warkton Tornado No.1 wrote:davet wrote:Fitted correctly and always used recommended oil, which was changed regularly. The bearing's done about 15k. Will be sending it to MB to let them know. I hope it's sent back to manufacturer for a look see. I ain't blaming MB coz the problem lies somewhere else.
The bearing failure is most likely due to a defect on the part of the supplier to MB, but presumably the choice of supplier & ultimately the quality control are down to him.
If you read his own opinions on many products, he has a lot to say about his competitors, most notably other Clubman type exhausts that he says “fall to bits!” Bizarrely, that does seem to be occurring with the Big Box system as Forum members can testify.
Personally, I’ve known other products of ‘his’ manufacture fail, such as the drive sprocket centre bolt.
Presumably he’s managed to make a good enough profit over the years, so I don’t feel much sympathy toward him.
Fast n Furious wrote:Thankfully, it's rarely we see this situation and as alarming as it is, it can and does happen.
I've seen it, and attributed it to detritus entering the bearing from a disintegrating duplex chain. Looking at that bearing with its failed cage I'm thinking, perhaps it's more a design and application failure than a product failure. A design that could filter the lube oil before tying to use it might be all that's needed.
Top tip:- Always use magnetic drain plugs.
Phil D wrote:Am I correct in thinking that "lapping " in the cone and hub you should use valve grinding paste ?
Also what's the best way to actually do it (an old layshaft perhaps)?
