Fast n Furious wrote:Does it rev out ok in 3rd gear?
Leotech wrote:I've had the replacement rubber tipped float needles with the red tip be about 1mm longer than the standard one.
It runs fine until you go flat out for any length of time, then it just dies like you're running out of fuel, then you shut off for 30 seconds, then its fine again.
check the length of the float needle against the original one.
P D: SC Chester wrote:...... And to cap my bad day off, the Mrs recons the grout in the bathroom needs more urgent attention than my scoot
Users browsing this forum: No registered users and 219 guests
