Tubeless rim tyre fitting, N Essex/S Suffolk
Postby Knowledge » Thu Apr 20, 2017 2:42 pm
Any suggestions for a tyre fitter with a proven success rate for Colchester or Ipswich area?
This is for SIP rims
Re: Tubeless rim tyre fitting, N Essex/S Suffolk
Postby suffolkts1 » Thu Apr 20, 2017 10:43 pm
Martin
Mototechniks in Stowmarket have fitted 6 for me and other members.
http://www.mototechniks.com/
suffolkts1
Postby Mel K » Fri Apr 21, 2017 6:12 am
https://uk.video.search.yahoo.com/video ... =124tqsr3v
Maybe try this ?
Watch your knee though :roll:
Mel K
Postby pauLI » Fri Apr 21, 2017 8:29 am
Knowledge wrote:Any suggestions for a tyre fitter with a proven success rate for Colchester or Ipswich area?
Ask Fat Phil as he has a bloke he recommends in Colchester but i can't for the life of me remember who he said
cheers
pauLI
Postby Storkfoot » Fri Apr 21, 2017 8:38 am
I'd be amazed if that cable tie method worked with a 10" wheel!
Good tip about using an air compressor at the end though :-)
Postby Knowledge » Fri Apr 21, 2017 8:53 pm
I was with a motorcycle tyre fitter yesterday who had a couple of very bad experiences with tyre fitting on SIP rims, but he was VERY keen to overcome the issues. We acknowledged that there are greater problems with smalltyres than with big wheel.
If you need to stretch a true by, say, 5% to get it to fit, then you will get more stretch on a 17" tyre than on a 10" (I think you know what I mean). He also suffered with the rim slipping on the machine.
I will try some of these suggested suppliers, as I don't really have time to waiter for my problem solving tyre fitter to solve all his problems.
Postby superhooper » Fri Apr 21, 2017 11:49 pm
Get some decent split rims, wack a tube in job done. If assembled correctly they're good in my opinion.
superhooper
Postby Knowledge » Sat Apr 22, 2017 10:34 pm
Ahh. Hopper, my lifestyle coach.
I got them fitted at MoT a bike at Colchester. Rather expensive, but not a scratch on the polished ali or the paint, and they did it the same day. If I had a little more time, I might have tried elsewhere, but no scratches and quick turn around was a result.
Postby Mel K » Mon Apr 24, 2017 5:16 pm
Storkfoot wrote:I'd be amazed if that cable tie method worked with a 10" wheel!
Paul, you could quite possibly be pleasantly surprised too, I don't have tubeless rims but it looks worth a go to those who do .
Mel K
Postby Storkfoot » Mon Apr 24, 2017 7:42 pm
Mel, I'd wager a beer and a chaser that noone could could a 10" tyre on like that without divine intervention. Even a soft walled one like an S1 :P
Users browsing this forum: Charliescooter and 227 guests
