Trail Tech Temperature Sensors
Postby Paul_from_Thornbury » Mon Apr 17, 2017 5:19 pm
What are experiences of these, chatting to the guy who sells them he says by far his biggest sales are to Lambretta owners.
I am on my third unit now, the first one failed as fitted over winter and apparently the LCD lower temp limit is 0 deg C and my screen failed. Unit replaced under warranty, the second one was hyper sensitive and would flicker between the three settings, time/max temp/current CHT temp, when the engine was running.
On to my third unit, this one is not so sensitive but cannot be hard mounted, so I've got it on a bracket with several layers of sticky back Velcro fixing to a bracket to ensure it doesn't flicker. The stainless bracket itself is also isolated by rubber washers.
Any experiences of other users?
Paul_from_Thornbury
Users browsing this forum: Solid Air and 4 guests
