andy-francis wrote:Also you may need to take the casing off and put a clutch compressor on it to see if the clutch is clearing when screwed In, sometimes you may need to remove 1/2mm from the end of the cluster to allow more travel on the clutch centre push rod this will eliminate any drag! if your a bit unsure give me a call 01228 675187 and I will talk you through it.
