Side case gasket face
Postby daniel whiteley » Mon Apr 03, 2017 1:46 pm
Howdy chaps just building an engine for the gp curry burner and I've had to weld a couple of stud holes and tap them out , this was easy enough but I need the gasket face on engine case and side case "skimming" as such , just took it down to local engine place and they hummed and arrggghhed quoting me more than £100 as they were going to struggle clamping them down , any ideas of were I could get it done /anyone had it done ? And before it's said the side case is a little too warped to go down the wet n dry on met route
I'm in Sheffield but work in Doncaster so time is a limit on getting to places when they are open due to working hours
daniel whiteley
Re: Side case gasket face
Postby dickie » Mon Apr 03, 2017 5:27 pm
I had a slightly warped one. Ktf scooters sell thick cork gaskets. Sorted mine out.
You'd obviously have to remove any high spots with a file and some wet and dry but that's easy enough.
Postby Watfordwhite » Mon Apr 03, 2017 7:47 pm
Glasgow Lambretta sell cork gaskets in lots of thicknesses. Could be worth trying one of these.
Watfordwhite
Postby Tractorman » Mon Apr 03, 2017 9:25 pm
Club shop also sell cork gaskets.
Postby Toot » Mon Apr 03, 2017 11:15 pm
Tractorman wrote:Club shop also sell cork gaskets.
Beat me to it ;)
Yes, 1.5mm thick Chaincase Cork gaskets now available through the LCGB Club Shop, £5 each. The manufacture states they are re-useable at least 5 times.
Available at all outings for the Club Shop this year: viewtopic.php?f=15&t=7798
If you can't make any of these events in person and would like to purchase, send me an email and we'll sort something out (including a small postage cost): lcgbshop@btinternet.com
Toot
Postby corrado » Tue Apr 04, 2017 12:08 am
Try Paul Gillow at Oiltek, he might be able to skim the casing for you. He's in Barnsley.
corrado
Postby daniel whiteley » Tue Apr 04, 2017 9:19 pm
Cheers chaps I've managed to reduce most of the warping so will just get a cork gasket
daniel whiteley
Postby Ian-B » Fri Aug 18, 2017 11:24 am
Old post here but worth bringing up again for feedback.
I used a cork gasket on my GP200 fairly recently, I had replaced a stripped exhaust bracket crankcase stud with a repair stud and thought it might prove to be good practice. I found that the gasket creeps too much and and the nuts need tightening after a fairly short run, I'm a bit wary of overtightening to compensate in case I strip more studs.
I can understand that they might be used to help with uneven gasket faces but I reckon I'll return to using fibre gaskets and Hylomar which was my preferred method.
Just wondering now how anyone else had got on with using Cork Gaskets.
Ian-B
Postby Fast n Furious » Fri Aug 18, 2017 1:07 pm
You will get "Creep and leak" problems with cork. Cork is fine for lightweight applications such as a rocker cover gasket which only needs light torque fasteners. Lammy chaincase covers form a structural part of the engine's construction, so the gasket needs to take the compression of the fasteners. A cork gasket here is not a good idea.
Postby a-teamlambretta » Fri Aug 18, 2017 1:23 pm
bgm mbd do one with a silicone bead along with a mag flange gasket
https://www.bgmproducts.co.uk/spares/bg ... 0916k.html
a-teamlambretta
Postby rossclark » Fri Aug 18, 2017 10:04 pm
Lambretta upgrades do quality British made gaskets isn 1 and 1.5 mm
Postby mickbooth » Wed Aug 23, 2017 9:48 pm
I had a slight weep on my Li150. I just put another gasket on, so you have two on now, and torque up properly. No weeps, and no messy gasket paste, simple!!!
mickbooth
Users browsing this forum: Baidu [Spider] and 75 guests
