Indian GP headset - hydraulic master cylinder options
Postby Knowledge » Mon Feb 20, 2017 1:19 pm
Hi,
I have an Indian "thick" headset and I was planning to fit an LTH master cylinder (nice kit) but they don't make one for the Indian headset. Apparently, the LTH item can be accommodated on the thick headset with some fettling, but I don't want it to look like a compromise.
I need the trapezium shaped light switch too. I have not decided on which master cylinder to use instead of the LTH.
What solutions have you guys got out there?
Re: Indian GP headset - hydraulic master cylinder options
Postby bike grim » Mon Feb 20, 2017 1:26 pm
I have just bought an LTH for S1/2 and that isn't a straight fit anyway which is disappointing considering its a CNC product. You have to loose meat off the tapered part of the headset apparently ( Marco emailed me to confirm) due the fact that not all the headsets are the same.
Postby Knowledge » Mon Feb 20, 2017 3:25 pm
I have been looking at some of the traditional solutions to this problem (a re-cast switch housing & m/c master cylinder) and they seem quite cheap by comparison to the LTH/MWW solution.
Postby gizmo » Mon Feb 20, 2017 6:58 pm
I might be completely wrong as I often am but I'm certain when I bought one at rayspeed they asked if I wanted Italian or Indian fitting. The casa one looks pretty good and comes in Indian fitting but ain't cheap
gizmo
Postby Knowledge » Mon Feb 20, 2017 8:18 pm
gizmo wrote:I might be completely wrong as I often am but I'm certain when I bought one at rayspeed they asked if I wanted Italian or Indian fitting. The casa one looks pretty good and comes in Indian fitting but ain't cheap
"When you bought one", do you mean, an LTH master cylinder? I didn't know Ray sold them.
I spoke to Martin Robinson, and he told me that they didn't do an Indian fitting, perhaps it was only the trapezium switch type that didn't come in Indian fitting.
I will check out the Casa item, as I haven't seen that, though my pockets aren't that full.
Postby gizmo » Mon Feb 20, 2017 10:25 pm
Yip, Rayspeed sell them
gizmo
Postby corrado » Tue Feb 21, 2017 2:48 am
I'll probably have the standard Scootrs or Sterling Indian Li style {trapezoid?] amongst my wares Martin.
I also have some adapters that bolt onto your existing none hydraulic light switch housing and then you can use any motorbike master cylinder, quite good if you want to use something a bit trick from a m.bike.
corrado
Postby Jim Rose » Tue Feb 21, 2017 7:59 am
Seems like you are going to a great deal of trouble to accommodate an Indian headset have you thought of getting and Italian headset and you'll have non of the trouble
Jim Rose
Postby gizmo » Tue Feb 21, 2017 6:02 pm
Jim Rose wrote:Seems like you are going to a great deal of trouble to accommodate an Indian headset have you thought of getting and Italian headset and you'll have non of the trouble
That's easier said than done. Tried to find one lately
gizmo
Postby Knowledge » Tue Feb 21, 2017 11:46 pm
Jim,
I had a matching pair of Italian headset, but they were worth £200, so I sold them and bought a new Indian item for £40. Frankly, I have a whole heap modifications to make to the headset, it would have been a crime to do it to an Italian item.
Gizmo,
AF sell what? The LTH Indian master cylinder, or a re-cast switch housing to take a motorcycle master cylinder?
Martin H,
I will be in touch.
Thanks everyone.
Postby Jim Rose » Wed Feb 22, 2017 7:48 am
[quote="Knowledge"]Jim,
We agree on that one! I didn't know what you were doing. I had the same issue with my current project cut good original stuff of bought new. I made the same choice as you. Good luck on the hunt, that's half the fun
Jim Rose
Postby gizmo » Wed Feb 22, 2017 4:33 pm
I bought the lth master cylinder from Rayspeed with the Italian headset fitting. I just seemed to think at the time I was asked if I wanted Indian or Italian fit. I appear to be wrong on this one as I have looked on lth site and they do everything apart from an Indian fitment. I apologise but the casa performance one looks good and it definitely is available with Indian housing.
gizmo
Postby Knowledge » Wed Feb 22, 2017 6:33 pm
Gizmo,
I have re-checked the Rimini site and they do an Indian headset version, but not for the trapezium shaped switch.
It looks like my options are diminishing.
Postby gizmo » Wed Feb 22, 2017 10:29 pm
Knowledge wrote:Gizmo,
Nothing is straight forward or simple with these things hope you sort something out.
gizmo
Postby Scooterlam » Sat Feb 25, 2017 3:16 pm
Do you mean LI type?
Scooterlam
Postby corrado » Thu Mar 02, 2017 4:12 pm
Knowledge wrote:Martin H,
I will be in touch.
I'll have those options with me at Wicksteed Martin.
corrado
Postby Knowledge » Thu Mar 02, 2017 4:17 pm
Nice. I just found a silver hydraulic cylinder from ebay at a good price, so I will be interested to see what you have got.
See you there.
Users browsing this forum: Baidu [Spider] and 49 guests
