hydraulic slave cylinder identification...
Postby byron » Sat Feb 18, 2017 4:19 pm
can anyone id this brake cylinder..?
old school hydraulic conversion on oe front disc.
done in the 90s at least, if not before.
It is leaking, I can probably get a new seal, but not sure if bore is too worn...
So, ideally a new replacement of the same...
[otherwise could enlarge cylinder bore and have another piston made..?]
don't think it's an MB one, Taffspeed maybe...?
thanks
byron
Re: hydraulic slave cylinder identification...
Postby martyn dwane » Sat Feb 18, 2017 4:53 pm
Not A DJ Webster one, does look like my mates and that is a taffspeed one, try contacting Ian Frankland.
martyn dwane
Postby byron » Sat Feb 18, 2017 4:59 pm
martyn dwane wrote:Not A DJ Webster one, does look like my mates and that is a taffspeed one, try contacting Ian Frankland.
yep, good idea, will do that.
byron
Postby rossclark » Sat Feb 18, 2017 8:32 pm
Dug out a few more pics of the Taffspeed one with the mini piston
Postby byron » Sat Feb 18, 2017 8:36 pm
excellent, thanks again Ross.
that is different, two seals then...
and the thread pitch looks finer than the one I have in.
byron
Postby rossclark » Sat Feb 18, 2017 8:55 pm
It's always possible they made different versions, but Ian F ID'd that one and told me what the piston and seals were from.
The outer seal is more of a dust cover than a seal proper.
Postby byron » Sun Feb 19, 2017 11:56 am
Chiselspeed seems to be the consensus.
thanks for replies
byron
Postby byron » Sun Feb 19, 2017 1:39 pm
byron wrote:Chiselspeed seems to be the consensus.
or not, but they can bore it out and fit one of their pistons, so that likely to be the way forward.
byron
Users browsing this forum: No registered users and 86 guests
