Knowledge wrote:I pet seal (or equivalent) my last tank, but the stuff came off the walls of the tank and clattered around inside until I could break it up into small enough pieces to get it out. What a faff!
I am building a new tank now, but I won't be sealing it. I will weld it and test whilst dry, as described below.
Cut around the valve of an old inner tube (leave a good 2" around the valve)
secure the rubber/valve over the neck of the filler using a jubilee clip
Insert the tap, secure it and turn it off
Use a hand or foot pump to put some air in the tank
Use a paint brush to slap a strong mix of washing-up liquid and water about all the external joints (watch for big bubbles and tiny bubbles)
Re-weld any leaks and repeat until this test is successful
Fit the tank to the scooter, fill with fuel, ride like you stole it.
Rich Oswald wrote:I have always used these products without issue:-
http://www.tankcareproducts.co.uk/
Feersum Injun wrote:Just got my hands on a nice new mild steel mid-range tank. Would you seal it or just fill it with petrol?!
Mel K wrote:Just re read your post , it's new . You'll need to swill it out and when it's c Lean fit it and fill it up , Defo no pet seal needed .
Ever !
Chemical stripping has seen to that .
Warkton Tornado No.1 wrote:Feersum Injun wrote:Just got my hands on a nice new mild steel mid-range tank. Would you seal it or just fill it with petrol?!
I agree that you shouldn’t need to seal the tank.
However, with old tanks that have rust, I’ve always tried to get an acid, such as phosphoric to attack the corrosion. Obviously, you need to be very careful. I’ve even used a good drain cleaner of the type you buy from Plumbers Merchants, again with lots of care.
However, this Post really reminds me of the thought I’ve long had that Lambretta tanks could be so much more flexible in size & manufacture if they were fitted with bladders or bags of the type used in Motorsport, Marine or even RC Models.
The ’tank’ then becomes just a ‘housing’ or ‘shell’ to protect the lining.
If the bladder were strong enough, you could even fit one in the toolbox that would get use on longer jaunts to increase the range whilst still allowing a few (non sharp) tools to share the space.
Sorry. I’ll get me coat...
Users browsing this forum: No registered users and 126 guests
