by drivera » Thu Aug 14, 2014 8:10 pm
Bought some scootRS tubeless rims which I intend to fit tyres to myself but I've just inserted one of the screw in type valves which came with it and it sticks up quite a way inside the wheel rim , has anybody fitted tyres themselves to these rims and if so does the tyre clear the valve without any problem or should I ditch the screw in type valves and get some push in ones ??
drivera
by mr series 2 » Thu Aug 14, 2014 8:34 pm
Are you talking about Scoot RS steel tubeless rims if so I've fitted my own tyres valves were not a problem
mr series 2
by foremanbob » Thu Aug 14, 2014 9:16 pm
^^ +1
foremanbob
by gaz_powell » Thu Aug 14, 2014 10:11 pm
I think ScootRS recommend the screw in type now and moved away from the push in type
I was given a set of rims and made a jig for fitting tyres to these rims from half a rim with some box section welded so it cab be held in a vice - put some long bolts/extended nuts through the rim so that the tubeless rim can be mounted -makes mounting alot easier - I used two big tyre levers and some mounting paste I blagged from the tyre centre round the corner.
I had a pair of Dunlop k688`s lying around and used them to test it - Ive not used them but the they have stayed up.
Gaz
by rossclark » Thu Aug 14, 2014 11:03 pm
I put Bridgeport style 90 degree valves in them. I had to cut a little bit out of the rim and flat off the face of the rim but they're still up.
by scootersi » Sat Aug 16, 2014 10:39 am
I use the push in brass/rubber valves which I replace every few months by pushing the tyre off the rim enough to get to the valve hole. Pressure stays up well.
scootersi
by IaninDorset » Wed Aug 20, 2014 12:01 am
Melvs Weld do this lovely gadget if that's any help?
https://www.melvsweld.co.uk/tyre-changing-bracketI intend to spend a fair bit there when I get to the stage of personalising once my Li is all built up, I bought a DM boot brake pedal from them at WSM for my T5 and it looks the biz as I plastidipped it in dark red.
IaninDorset
by drivera » Wed Aug 20, 2014 11:33 am
Ta for the comments lads , I think I have found something to hold the rim steady whilst I fit the tyre , my old RAMP rear hub clamped in my workmate with the studs fitted wrong way round should do the job nicely
drivera
Users browsing this forum: nsaints and 22 guests
