PHBL 24MM CARB ADVICE
Postby northernpete » Mon Jan 23, 2017 8:56 pm
ANY POINTERS ON BASE JETTINGS......STANDARD SIL 200 LUMP,BREATHING THRU AIR BOX WITH A SCOOTOPIA 42MM CLUBMAN/ANCILLOTTI. PLENTY OF ADVICE FOR 25MM,NONE FOR 24MM ;) USE 25MM AS A GUIDE?
northernpete
Re: PHBL 24MM CARB ADVICE
Postby Cgt75b » Thu Jan 26, 2017 4:30 pm
What jets are you running at the moment?
Postby northernpete » Thu Jan 26, 2017 8:52 pm
NOT RUN IT YET AS .....BUT THIS IS HOW ITS JETTED AT MO...
60 STARTER
50 PILOT
105 MAIN
D22 NEEDLE (3 DOWN)
40 SLIDE
AQ266 ATOMISER
GOT THESE FROM A GUY WHO WAS RUNNING CARB ON AN RT195 WITH A BGM BIG BOX EXHAUST AS I WAS ORIGINALLY GONNA RUN IT ON AN SR185 BEFORE I BOUGHT THE GP...
northernpete
Postby Cgt75b » Fri Feb 03, 2017 11:21 am
I would say run it and see how you get on.
Postby northernpete » Fri Feb 03, 2017 9:28 pm
Cheers.....sounds like a plan....gonna be a couple of weeks...forks out at mo being rebuilt....will let u know how I get on :)
northernpete
Return to Carburettors
Users browsing this forum: Google [Bot] and 3 guests
