Andie wrote:
Is the Saatchi model any different, apart from £70, from the Scootopia version? -
Andrew
Andrew
It has a completely different down pipe http://www.ebay.co.uk/itm/111987135389? ... EBIDX%3AIT
Andie wrote:Thanks Corrado. Without wanting to totally hijack jefft's post, i'm interested in the differences as I'm pondering between ceramic coating a replacement Clubman u-bend, or going for an Ancillotti, and if the latter which one... I guess a longer pipe gives a lower note.
Andie wrote:I like the look of the Ancillotti as it has a chrome down pipe (my Clubman u-bend has lost all its paint in a year and cannot be tightened without removing the cowl as the bend prevents socket access on Flywheel side) But I've read mixed reviews about the A's fitting, including blocking oil level plug access.
The Scootering review http://www.scootering.com/exhausting/ favoured the Clubman - on cost as much as anything else -
Andrew
corrado wrote:Hmmmm, I've got both [new] I must look closer at the down pipes as at a quick glance I'd never noticed any difference [apart from the obvious £70 lol]
corrado wrote:corrado wrote:Hmmmm, I've got both [new] I must look closer at the down pipes as at a quick glance I'd never noticed any difference [apart from the obvious £70 lol]
Having put them side by side and one on top of the other there is very little difference. The downpipe on the Ancillotti isn't quite as rounded as the "U" in the downpipe on the Scootopia but it's pretty negligible and I'd be amazed if it had any effect on the running performance. I do like the fact that the Ancillotti one has the name embossed on the box section, albeit in a place where you can't see it, but I don't like it £70's worth.
dickie wrote:Andie wrote:I like the look of the Ancillotti as it has a chrome down pipe (my Clubman u-bend has lost all its paint in a year and cannot be tightened without removing the cowl as the bend prevents socket access on Flywheel side) But I've read mixed reviews about the A's fitting, including blocking oil level plug access.
Andrew
I had one on my bike for a while. The chrome down pipe was actually bright zinc plated, and burnt off in a couple of hundred miles. Weirdly it was stainless steel underneath so I just cleaned it up and all was well. Yes it blocked the drain plug.
The stub is also odd as it has a smaller cross section than a big bore gasket so I had to open it out or it wouldn't really be a 42mm clubman, more like 38mm.
Seemed nicely put together and I'm keeping it for a project I have on the back burner.
HxPaul wrote:
According to these photos,the downpipes are different.http://www.ebay.co.uk/itm/LAMBRETTA-GP- ... 282602efd4
