Piston Cut for reed valve
Postby DaveTomo » Mon Jan 09, 2017 8:36 pm
I've got an 66mm Asso piston knocking around in the shed from a few years ago when I had a 200 rapido. Anyway rather than splashing out on a new piston to carry as a spare, any recommendations for someone to cut/alter this piston? Its to go in a GT200 big block kit so need it altering to suit a reed kit I am assuming this will fit as well crown height etc. I just want one spare "just in case". Appreciate your help
DaveTomo
Re: Piston Cut for reed valve
Postby Warkton Tornado No.1 » Mon Jan 09, 2017 8:49 pm
I fully understand your question & an expert will be along shortly, concerning the GT kit. I seem to recall Dimitrios posting on here some images...
However, if the piston is purely as a back-up, it will run anyway, regardless of cutouts, surely?
That way, if not put into use in the scenario you describe, it could serve elsewhere.
Just saying.... ;)
Postby DaveTomo » Mon Jan 09, 2017 8:56 pm
Aaah I see :) to be honest this is my first time with a reed kit , always been piston ported prior to this, iron barrels, and various rapido's, so wasn't sure if a "normal" piston would work.Basically its my back up piston for the Euro, so with a healthy sense of paranoia I'm trying to cover all bases. So it would work then as is without being cut?
DaveTomo
Postby Warkton Tornado No.1 » Tue Jan 10, 2017 1:25 pm
It would run. You could perhaps try it to convince yourself prior to your trip for peace of mind... :)
I am aware that many tuners seek completely 360° inlet timing with reed valve inlet ports into the barrel, but that is a 'swings & roundabouts' scenario in which any ultimate power can be offset by the loss of reliability/increased wear due to lack of piston strength & exasperated 'rocking' of the piston in the bore.
My comments are only intended to help ;)
Postby dscscotty » Tue Jan 10, 2017 6:10 pm
The GT kit i believe uses a Yamaha piston so the crown height as well as the dome height is different to the Asso
Postby Warkton Tornado No.1 » Tue Jan 10, 2017 6:36 pm
Unread postby dscscotty » Tue Jan 10, 2017 6:10 pm
:oops:
You are quite correct & I apologize for missing the obvious!
I think the ('central') compression height is 36 mm as opposed to 39 mm...
Postby Fast n Furious » Thu Feb 02, 2017 11:01 pm
:oops:
I concur.
You could of course carry a 3mm base packer with this Asso and hope you have sufficient adjustment to re-fit the exhaust and cowlings.
Change the piston back to a Yam one when you get home though cos those Asso's don't last.
Might just be easier to fork out the £50 or so for a spare Mitaka though?
