fAST FLOW FUEL TAP
fAST FLOW FUEL TAP
Postby sherpadean » Thu Jan 05, 2017 11:35 am
Hi everyone & happy new year,
After fitting a fast flow fuel tap to my standard '66 125 Special I'm having a problem - it works fine but the fuel on/off lever is stiff to turn - I've tried moving the tap in various positions is there a 'knack/trick' or am I missing something? Any advice welcome.
Mike
sherpadean
Re: fAST FLOW FUEL TAP
Postby Knowledge » Thu Jan 05, 2017 8:17 pm
I bet I am not the only one wondering why you have bought a fast flow tap for a standard scooter.
Have you tried turning the whole tap through 90degrees and operating without the complication of the routing? Just to see if the operation is easier.
Postby Mel K » Thu Jan 05, 2017 8:57 pm
What make of tap is it ?
Reason I ask is because I've used a few fast flow taps and always get the Italian OMG ones and they've all worked as they should .
Mel K
Postby missing lynx » Thu Jan 05, 2017 9:30 pm
some times the screws are over tightened try loosening one of them it may only need less than 1/4 of a turn
Postby Norrie Bodge » Thu Jan 05, 2017 11:30 pm
Scootopia Fast Flow ones best IMO
Norrie Bodge
Postby sherpadean » Sat Jan 07, 2017 11:27 am
Thanks everyone - now sorted it after trying several more positions - it's working well though the fuel lever protrudes a little way [about 1''] from the bodywork but I can live with that in the short term...it's an OMG tap by the way
Again thanks fellow Lammies !
sherpadean
Postby sherpadean » Sat Jan 07, 2017 11:30 am
I'm using fast flow tap on standard scoot following 'Sticky's' advice in his Guide....thanks again everyone.
sherpadean
Postby HxPaul » Wed Jan 11, 2017 3:31 pm
sherpadean wrote:Hi everyone & happy new year,
Mike
Sometimes the split pin on the universal joint catches on the carb.
Postby sherpadean » Thu Jan 12, 2017 1:11 pm
Thanks Paul
sherpadean
