Ts1 panel won't go on
Postby Blaginit » Wed Dec 14, 2016 3:18 pm
Hi just had full af ts1 fitted all from Af rayspeed only trouble side panel won't go back on phbh delly fitted didn't want hole in panel is there anything I can do or do I just have to put a hole in panel cheers for any help merry x mas
Blaginit
Re: Ts1 panel won't go on
Postby missing lynx » Wed Dec 14, 2016 4:02 pm
did you tell AF that you wanted it to fit under the panel ? as they do do special stubby manifolds to allow this
Postby coaster » Wed Dec 14, 2016 5:42 pm
If you use a short carb mounting rubber (MB do them) it might be possible to get the panel on with a GP style bellows and RAM type filter but as the previous poster said, you really need to plan for it and fit something like the LTH manifold and maybe a Mikuni, PWK or a flat slide Delly all of which are shorter carbs
Postby gaz_powell » Wed Dec 14, 2016 6:54 pm
I run a 34 vhsb on MB manifold with no cut out on GP panel, same on SX, carbs have machined fronts. There's not much clearance but no running issues.
Would have thought a phbh would have fit no problem even on a standard af manifold - has the carb got a plastic screw on/off bellmouth?
Postby Blaginit » Wed Dec 14, 2016 8:38 pm
gaz_powell wrote:I run a 34 vhsb on MB manifold with no cut out on GP panel, same on SX, carbs have machined fronts. There's not much clearance but no running issues.
Thanks for that I would never have Sussed it :oops:
Blaginit
