Post by ToBoldlyGo » Tue Dec 13, 2016 2:58 pm
Hah! That's ironic, people complaining about bench seats restricting airflow on a S2 with possibly the most restrictive air scoop, box set up of the lot. You'll be fine with a bench seat providing you carry out a few simple tasks to improve the air flow. Things like removing the baffle in the scoop for a start. The air box is a bit more tricky, because the neck will be restrictive. You'd either have to fit an airbox from a 175 or use a S3 airbox. But then that would mean you'd need a S3 toolbox as well. Alternately you could drill holes in it.
ToBoldlyGo wrote:Hah! That's ironic, people complaining about bench seats restricting airflow on a S2 with possibly the most restrictive air scoop, box set up of the lot. You'll be fine with a bench seat providing you carry out a few simple tasks to improve the air flow. Things like removing the baffle in the scoop for a start. The air box is a bit more tricky, because the neck will be restrictive. You'd either have to fit an airbox from a 175 or use a S3 airbox. But then that would mean you'd need a S3 toolbox as well. Alternately you could drill holes in it.
Warkton Tornado No.1 wrote:Post by ToBoldlyGo » Tue Dec 13, 2016 2:58 pm
Does this now apply to all SII's or just those that have been modified & need more air? I apologise for my ignorance if so, but I presume that a standard SII air induction side will cope adequately with the standard carburettor/barrel/exhaust set up.
I guess any modifications as you suggest can do no harm, but I was thinking that any changes should be kept to a minimum if the bike runs well & all he's seeking is advice on a seat.
Post by ToBoldlyGo » Tue Dec 13, 2016 7:41 pm
Nothing is compulsory White Tornado. I got a bit carried away, that's all.If it goes and he's happy with it don't knock it. But, if he's getting into it I should imagine that he might want a little more than that before long.
ToBoldlyGo wrote:Don't dispense with the two rubbers. You don't really want the seat frame resting directly on the catch plate. It's possible to bend the tongue in some cases so that it locks more smoothly. Or, you may need to elongate the hole in which the catch locks slightly. You do have rubbers mounted beneath the catch plate I take it? If you're having to drop the seat to get it to take the actual catch plate might be too low. Hence my question about the rubbers.
Users browsing this forum: L111amo and 63 guests
