Complete Spanners Manual 3rd Edition
Postby Sticky » Mon Dec 12, 2016 9:30 pm
Right folks, here's a question.
In the next few months we are going to be updating the Complete Spanners Manual for Lambretta and I'm looking for your suggestions on stuff I should change or add.
1. Are there any corrections that you've noticed I should fix?
2. Is there anything you'd suggest that we can add as a section?
3. Are there any newly-developed parts that you think we should cover?
4. Do you know any new techniques that we should add?
All suggestions welcome
Sticky
Sticky
Re: Complete Spanners Manual 3rd Edition
Postby Adam_Winstone » Mon Dec 12, 2016 9:33 pm
Get 8073 out of the GP colours list. ;)
Postby swissdean » Mon Dec 12, 2016 9:43 pm
Add servers lince/lynx and I'll buy my 3rd edition
Especially ignition
swissdean
Postby Sticky » Mon Dec 12, 2016 9:43 pm
Adam_Winstone wrote:Get 8073 out of the GP colours list. ;)
All suggestions apart from that one :)
Sticky
Postby Sticky » Mon Dec 12, 2016 9:44 pm
swissdean wrote:Add servers lince/lynx and I'll buy my 3rd edition
Especially ignition
Good suggestion
Sticky
Postby MickYork » Mon Dec 12, 2016 9:47 pm
Samaritan's number................... :mrgreen:
Postby Sticky » Mon Dec 12, 2016 9:47 pm
MickYork wrote:Samaritan's number................... :mrgreen:
I think we can find room for that
Sticky
Postby Adam_Winstone » Mon Dec 12, 2016 9:49 pm
A bit about the basics of advance retard ignitions as these are becoming the norm.
Perhaps a bit about basic long-stroke format, based on 60mm stroke cranks becoming a common upgrade.
Advice and tips for swapping out hub studs for tubeless (or simply for hub repair).
Hydraulic front brake upgrades.
Get 8073 out of the GP colour options.
... etc
Postby Sticky » Mon Dec 12, 2016 9:52 pm
... etc
Sticky
Postby Adam_Winstone » Mon Dec 12, 2016 9:53 pm
Nope
Postby Marty ULC » Mon Dec 12, 2016 9:54 pm
Get-you-home bodges.
The LCS did a booklet of them.
Marty ULC
Postby Sticky » Mon Dec 12, 2016 9:54 pm
Something about these too I suppose
http://www.scooterlab.uk/lambretta-casing-wars/
Sticky
Postby Sticky » Mon Dec 12, 2016 9:55 pm
Marty ULC wrote:Get-you-home bodges.
Do you think you could find me a copy Marty?
Sticky
Postby eddie15b » Mon Dec 12, 2016 10:01 pm
taking things from a "newbie" perspective
how to register to V5C an italian lambretta import A to Z
also once you have your lambretta fully registered a full chapter on
how to change your LI125 shopping trolley into a genuine euro rally compatible scooter
as in sit at 55-65 all day reliably with decent electrics/lights tyres suspension brakes etc
do this in a cheapskate - affordable - money no object sections
you dont have to denigrate anyone's products just "recommended through use"
these product have proven to be up to the job......
also same again with carriers/panniers/sat navs/chargers etc
so if i was 30 had only ever driven an auto scooter how could i
realistically set about getting to euro 2018 with a pushed out of
an italian cellar and brought over in a van - 1962 LI125 lambretta
cheers eddie
eddie15b
Postby Storkfoot » Mon Dec 12, 2016 10:17 pm
Air leak testing.
Postby Sticky » Mon Dec 12, 2016 10:21 pm
Storkfoot wrote:Air leak testing.
That's in hand
Sticky
Postby Sticky » Mon Dec 12, 2016 10:22 pm
eddie15b wrote:taking things from a "newbie" perspective...
Thanks Eddie
Sticky
Postby Scooterslag » Mon Dec 12, 2016 10:54 pm
as previously mentioned, more Spanish stuff espcially the lince/lynx . Paul ;)
Postby Warkton Tornado No.1 » Tue Dec 13, 2016 12:52 am
My immediate thoughts, which I hope you may consider are:
If some product or another is claimed to be better, I feel that there should be validation of it, rather than presuming that to be the case. Although lay-shafts & hubs may spring to mind, the rash of alloy gear change linkages may look worthy of appearing on page three of the Sun, but, how durable are they sat atop the equivalent of a road drill?
I’m not questioning any integrity of the purpose of the manual, because it clearly was prepared to point out misgivings with certain products, such as certain Vietnamese tubeless wheel rims...
I wouldn’t have thought it beyond your remit to have port diagrams of the proliferation of kit cylinders. Similarly, perhaps relevant piston & con-rod dimensions along the lines of what Grampian Motors produced would be good reference.
The manual has previously pointed out what other vehicles are prime sources of components for adapting to Lambrettas. The best coil to use with points is a prime example. That could be extended to clutches, ignitions as well as pistons & con-rods (as mentioned above)
That’s all....for now. :roll:
Postby daniel whiteley » Tue Dec 13, 2016 6:16 am
More detailed photos and maybe some links to videos of you doing some of the more difficult things explaining as you go ?
Last edited by daniel whiteley on Tue Dec 13, 2016 6:51 am, edited 1 time in total.
daniel whiteley
Users browsing this forum: No registered users and 17 guests
