EddieStone wrote:Is it definitely leaking out the cap? It's not leaking out of a join between the tank and the filler neck is it?
Yes cap .
coaster wrote:I'm having similar problems with a Diablo tank and a Camlam one. The caps (I've tried a few) need the tabs fettling just to allow the thing to turn an lock and then leak when full. I wish I'd tried the caps before fitting the tanks as it is the angle (or lack of) of the ramps in the neck that are the issue.
Users browsing this forum: Baidu [Spider], Google [Bot] and 69 guests
