Nicodemus wrote:Must admit it seems I must of had my studs round the wrong way - long end up, you live and learn. Why do you not like the Blue Hylomar mr W tornado? What is considered the best option for this situation as I have been using Hylomar.
Nick
Unread postby Nicodemus » Sun Nov 20, 2016 4:16 pm
Nick
Post by Knowledge » Sun Nov 20, 2016 8:30 pm
Update.
I then found air escaping up one of the four main studs. This is probably due to a repair I made after I broke through to the stud whilst fettling the transfers. More three bond on the fat washer at the top, and re-tighten the four nuts.
Knowledge wrote:Update.
I'm washing my linen in public here, so you all don't have to.
Phil D wrote:I'm washing my linen in public here, so you all don't have to.
I thought that was a very humble post .
Great thread great philosophy .
What could we achieve if we all were prepared to accept we can all learn something and we don't know as much as we think we do .
Thanks Knowledge .
Thanks Knowledge .
Post by EddieStone » Mon Nov 21, 2016 3:50 pm
I'm happy to be corrected here, but I thought the stud holes in the casing were deliberately not tapped to the full depth? This allows the stud to 'bite' into the shallower threads at the bottom so it doesn't come undone again...
Knowledge wrote:..... The factory recommendation on tightening the nuts was to get them all tightened down in a relevant order until they were all just biting, and then turn them all by a quarter turn (again in a pre-described order) and then go round again with another quarter turn again.
In fact, in my time, I have had to produce drawings of studs that do ‘bottom out’ for TWR Nissan amongst others.
They comprise an extended portion of Ø6.8 mm in the case of M8 x 1.25 with a conical end 118° that does the bottoming out.
The V*spa cylinder studs with their rolled threads would be ideal to modify to such purposes using the 'long' end.
They work well as they do not apply load to the threaded portion of the hole.
Users browsing this forum: Google [Bot] and 64 guests
