gt186-1 by Donnie Canning, on Flickr
gt186-2 by Donnie Canning, on Flickr
gt186-4 by Donnie Canning, on FlickrThe ability to post messages is restricted to LCGB members. Any questions contact us at lcgbadmin@googlemail.com
Post by Dimitrios_231 » Wed Nov 09, 2016 2:01 pm
Almost done,
ground control to major Tom![]()
“It can be seen that there’s some matching to do yet of the crankcase transfers port entries to the barrel.”
“I wondered if you are going to modify the top of the boost port which is controlled by the crown of the piston. Is there a current ‘school of thought’ for that angle? As it is, the theory remains that the boost acts as a ‘purge’ rather than a ‘fill’ which might still be best practice....for all I know!”
“I need to match and flow the middle port,it needs a little extra work.
If you are talking about this angle,it is 27 degrees (or 63),
I won't change it.”
Dimitrios_231 wrote:Thank you,
I won't use base and head gaskets,(threebond only),standard 58/107 crank with 1.15 squish and 22.5ml compressed volume.
(I just felt like I went for confession)
