Crank probs
Crank probs
Postby halesworthlambretta » Fri Aug 08, 2014 10:22 am
Help needed - fitted new crank to Spanish SX engine last night. The bottom of the con rod appears to be proud of the crank webs and at a certain point is catching on the engine case.
Any advice would be much appreciated
halesworthlambretta
Re: Crank probs
Postby coaster » Fri Aug 08, 2014 12:31 pm
Is it a standard type 58 stroke 107mm rod? also, was the mag housing fitted?
Re: Crank probs
Postby Rich Oswald » Fri Aug 08, 2014 12:41 pm
Sounds like you could have a 60mm stroke crank?
Re: Crank probs
Postby halesworthlambretta » Fri Aug 08, 2014 3:24 pm
Hi all - it's a 58 x 107
halesworthlambretta
Re: Crank probs
Postby halesworthlambretta » Fri Aug 08, 2014 3:26 pm
Hi Coaster - yes we fitted the mag housing
halesworthlambretta
Re: Crank probs
Postby coaster » Fri Aug 08, 2014 5:11 pm
halesworthlambretta wrote:Hi Coaster - yes we fitted the mag housing
What's the origin/make of the crank and are you sure it's rubbing at the big end eye and not on a poorly seated bearing retaining plate?
Re: Crank probs
Postby Adam_Winstone » Fri Aug 08, 2014 5:44 pm
I've only come across this with 60mm stroke cranks with standard rods :?:
Re: Crank probs
Postby halesworthlambretta » Sat Aug 16, 2014 2:10 pm
All sorted - wrong size; Adam was spot on. (Thanks for that mate)
Should be back together for Mersea
halesworthlambretta
Re: Crank probs
Postby Adam_Winstone » Sat Aug 16, 2014 2:17 pm
Rich twigged to this before I mentioned it but between us we managed to give you a seconded opinion that helped you to identify the issue. Nice to be part of a community that helps each other out :)
Adam
Re: Crank probs
Postby halesworthlambretta » Sun Aug 17, 2014 11:03 am
Sorry Rich - cheers mate.
I agree - it's all about helping each other out
halesworthlambretta
Users browsing this forum: Bing [Bot] and 15 guests
