Post by Covboy » Thu Nov 10, 2016 1:31 pm
That's what I was also hoping to understand-
I've got a Casa S2 42mm clubman already....I've also just acquired a JL expansion.....the main reason for sticking with the clubman is to avoid cutting my running boards....but if the gains in torque are suitably beneficial when fitting an expansion type exhaust, then I would consider it.
From 12/13lb (Train Driver) -19lb (Lambretta Sash) is a good difference.
Any other figures from similar set ups would be useful as comparisons..
I wish that a 30 PHBH Carb hadn't become a standard 'must-have' size.
Everything that I have read about matching a 30mm venturi with a stage 1-4 200cc engine and clubman exhaust screams that it is too big to develop good road power and run reliably
Are you suggesting that Mark Broadhurst is all theory and no practical experience ?![]()
