LI Series 2 Frame Loop
Postby andy8688 » Thu Sep 15, 2016 8:32 pm
Hi Guys, I have just had my frame back from the blasters and it has opened a few more wounds, there is a lot of peppering through the top of the frame loop and the inside of the tool box aperture, also dents on the top.
What is the best or the cheapest way to rectify, a new GRP frame loop as a steel replacement I know is rare, or fill the holes will filler (bodge up).
The frame itself is excellent. Any advice much appreciated.
Andy
andy8688
Re: LI Series 2 Frame Loop
Postby dickie » Thu Sep 15, 2016 8:36 pm
https://www.thescooterrepublic.co.uk/la ... sx200-p518
Out of stock and not cheap but maybe an option.
There are loads of good tinsmiths around. I would just pay a man to fix it.
Personally I wouldn't consider grp.
Postby andy8688 » Thu Sep 15, 2016 8:49 pm
Thanks, I will have a look around.
andy8688
Postby steve t » Thu Sep 15, 2016 8:53 pm
Try a local body shop maybe some one who deals with old cars there's not a lot that can't be repaired especially body wise
steve t
Postby daniel whiteley » Fri Sep 16, 2016 8:25 pm
if your anywhere near sheffield i can take a look for you
daniel whiteley
Postby andy8688 » Fri Sep 16, 2016 9:13 pm
Daniel, thanks. I am in the Midlands.
andy8688
Postby rossclark » Fri Sep 16, 2016 11:44 pm
Postby Digger » Sat Sep 17, 2016 5:55 am
rossclark wrote:http://lambrettafinder.com/shop/lambretta-series-1-or-2-frame-loop/
Nice price too (IMHO).
Digger
Postby andy8688 » Sat Sep 17, 2016 7:33 am
Thanks Guys, exactly what I am looking for.
Andy
andy8688
Postby johnnyXS » Sat Sep 17, 2016 8:41 am
If you cannot obtain a used hoop you could always consider brazing the rusty areas. I wouldn't attempt Mig or Tig welding as it will just blow the thin metal away.
If you use a large nozzle propane roofing torch you could use lead to 'lead load' the holes or
oxy acetylene to braze with brass . Either way will build up a non ferrous layer which is rust free and easy to skim. ;)
johnnyXS
Postby andy8688 » Sat Sep 17, 2016 5:50 pm
The worst area is inside the tool box aperture, it has completely rotted away and would need refabricacting. If I decide to change the frame loop what is the best procedure for removal.
Andy
andy8688
Users browsing this forum: No registered users and 32 guests
