Knowledge wrote:I assume that it was running OK prior to the breakdown?
MickYork wrote:The new stator might have incorrect timing marks and you might be over retarded. Check your timing with a strobe.
al pushpak wrote:Hi, might be worth trying the needle on the top clip setting & if you have access to one you could also try blowing all the jets & carb out with a high pressure air line hope, you get sorted. Al
Gary Harwood wrote:I'm no expert but my Mugello 186 developed a spluttering similar to your description. We changed the fuel tank....no better. Changed CDI, plug cap and lead.....no better. Thoroughly cleaned carb......no better. Eventually got it on a dyno and concluded it really was a fuel problem.....turned out to be the slide in the carb. Changed it from a 40 to a 50.....bingo! Now runs fine.
Users browsing this forum: Bing [Bot], Fast n Furious, Google [Bot] and 10 guests
