LDAVV STARTER
LDAVV STARTER
Postby Bettagetabrettabolti » Tue Jul 05, 2016 9:00 pm
Chaps
I need some advice on my LDA. The starter motor turns over fine - I have removed it to verify this - but the engine doesn't turn over. Anyone have any clues?
It starts fine on the kick start
Any help would be appreciated.
Bolti
Re: LDAVV STARTER
Postby Rob Miller » Wed Jul 06, 2016 6:29 pm
It sounds like the starter pinion is not engaging with the gearteeth on the outside of the clutch bell. Check the starter cable is moving the pinion fully and check the condition of the teeth on the pinion.
Rob Miller
Re: LDAVV STARTER
Postby Bettagetabrettabolti » Thu Jul 07, 2016 9:18 am
Rob
My thoughts exactly re pinion engagement.
Can you explain how to check if the starter cable is moving the pinion fully please.
Re: LDAVV STARTER
Postby Rob Miller » Thu Jul 07, 2016 5:28 pm
Take the starter motor out, operate the cable and watch what happens. Its a long time since I had one of these through my hands, Dave Waddingham might be a better man to ask as he has restored two in the last couple of years.
Rob Miller
Re: LDAVV STARTER
Postby Bettagetabrettabolti » Mon Jul 11, 2016 8:37 pm
Well have adjusted the cable both ways in and out and all I get is the gear on the motor turning. I can't see how this engages with the gear on the clutch.
Thanks god I still have a kickstart - although this defeats the object.
Bolti
Re: LDAVV STARTER
Postby Bettagetabrettabolti » Sun Jul 17, 2016 10:53 pm
Ok for those who would like to know. When the starter lever is pushed forwards the cable engages the contacts to initiate the starter motor turning whilst simultaneously the is a shaft that is depressed engaging the bendix onto the clutch cage that has a set of teeth like on a car flywheel mounted on it. This then turns the engine over. Ingenious piece of design by Innocenti!
Return to Pre 57
