rear hub cone
rear hub cone
Postby Freight10 » Fri Jun 24, 2016 7:32 pm
Hi all,
I'm after some help, I was changing my clutch springs the other day, I noticed while I was lying on my back that the rear hub had some movement, had a play with it, felt like on a car when the bearing is out..
So, hub off etc... lay shaft is fine, bearing seems perfect, so the only other assumption I can make, is the hub cone..
I brought the engine as a going concern, the hub and cone were in a box.
So my question is..., having looked through sticky's book, how do I measure the cone against the hub to make sure it's the right one for the hub.
How can something so simple be such a bas#*×@ :?:
Thanks in advance for your help
Trevor
Freight10
Re: rear hub cone
Postby johnnyXS » Fri Jun 24, 2016 7:41 pm
:lol: :lol: :lol: I won't ask why you were lying on the floor :lol:
I have exactly the same problem with my S3 so I'll be following this closely.
My hub has quite a wobble but no lateral movement, so like you I'm guessing its the cone thats worn. ;)
johnnyXS
Re: rear hub cone
Postby Freight10 » Fri Jun 24, 2016 7:44 pm
johnnyXS wrote::lol: :lol: :lol: I won't ask why you were lying on the floor :lol:
Shock of the cost :lol:
Freight10
Re: rear hub cone
Postby johnnyXS » Fri Jun 24, 2016 8:22 pm
:lol: :lol: most bills are best taken lying down :lol:
I'll keep my eye on this thread and see what you find .
johnnyXS
Users browsing this forum: Bing [Bot] and 70 guests
