Adam_Winstone wrote:
I've since heard of layshafts failing on others, after being correctly fitted and torqued up (not over-torqued), with the layshafts ranging from original Spanish or Innocenti to brand new SIL layshafts from a known source and/or on complete SIL machines (when available from new), and through to modern/new expensive aftermarket layshaft from a respected tuning house.
Adam
Wasn't there a spate of layshaft shearing a little while ago with people who were running R1 shocks on their machines?
Warkton Tornado No.1 wrote:Wasn't there a spate of layshaft shearing a little while ago with people who were running R1 shocks on their machines?
Paul
Thank you for the response.
Personally, that’s news to me, but others may verify your suggestion.
TBH, I immediately thought of sprinters that use no rear shock absorbers @ all. The tracks they use are not renowned for being smooth, either!
So, it would be great to have feedback from sprinters that have, or have not for that matter, experienced layshaft failure.
Adam_Winstone wrote:I always torque to just under the book value and then work up in smaller increments towards the correct value, meaning that I never find myself aiming for the exact figure and finding that I've just passed a hole and would have to torque considerably more to reach the next hole.
Funny thing is that there is video footage from the factory assembly line that shows the hub being done up without a torque wrench and then knocked round to the next hole with a spanner and mallet, hardly scientific or accurate!
Adam
Adam_Winstone wrote:Funny thing is that there is video footage from the factory assembly line that shows the hub being done up without a torque wrench and then knocked round to the next hole with a spanner and mallet, hardly scientific or accurate!
Adam
If we want to take this issue any further we need proper research.We first need a volunteer from within the LCGB to record any reported failures. Then we need funding to instruct an engineer to investigate the failure. We need one expert to look at them all as if we get more than one (expert) the results may not be consistent.
