help
help
Postby matt horton » Tue Jul 15, 2014 5:21 pm
Hello, Ive just changed the points on my li150(175) I took off the stator which had been marked on the magneto housing, reassembled using same marks, good spark but would not start, checked and remarked tdc and 19degrees btdc mark, used rollup paper to find opening point the original marks however do not match up, even when I turn the stator plate the most i can get is a firing point 26 degrees before tdc, the point at which the points are opening is also not to easy locate as points are moving out of view of the slots on the flywheel, have a feeling missing something really basic but god knows what, any help would be much appreciated
matt horton
Re: help
Postby coaster » Tue Jul 15, 2014 5:31 pm
Is the woodruff key still in place?
Re: help
Postby matt horton » Tue Jul 15, 2014 5:51 pm
Yes Key is still in place, I had the flywheel off initally because two of the grub screws holding magnets in place had come out and prevented the bike being kicked over, electrics aren't my strong point and Im at a loss to know where I'm going wrong.
matt horton
Re: help
Postby Wack » Tue Jul 15, 2014 6:05 pm
Set points at 15 thou with piston at TDC. If the gap is incorrectly set the timing alters and explains why your stator no longer lined up. If I remember rightly , too big a gap - timing advanced. Too small - retarded. A fag paper is ok but better to use a battery and bulb on the green stator wire and watch when the bulb dims as the points open.
Re: help
Postby MK Monty » Tue Jul 15, 2014 6:11 pm
am I missing something here but you have replaced the points, so the cam follower will be unworn eg longer. So your opening point and timing will net be in the same place. long time since I did points so shoot me if Im wrong
MK Monty
Re: help
Postby matt horton » Tue Jul 15, 2014 6:23 pm
MK Monty wrote:am I missing something here but you have replaced the points, so the cam follower will be unworn eg longer. So your opening point and timing will net be in the same place. long time since I did points so shoot me if Im wrong
This did enter my mind but putting side by side they are identical
Matt
matt horton
Re: help
Postby matt horton » Tue Jul 15, 2014 6:32 pm
Wack wrote:Set points at 15 thou with piston at TDC. If the gap is incorrectly set the timing alters and explains why your stator no longer lined up. If I remember rightly , too big a gap - timing advanced. Too small - retarded. A fag paper is ok but better to use a battery and bulb on the green stator wire and watch when the bulb dims as the points open.
Hello yes gap is set to 0.4mm however when points loose contact firing point is 30 degrees btdc with stator in same position as it was previously and even if i turn stator the best i can get is around 25
Matt
matt horton
Re: help
Postby matt horton » Wed Jul 16, 2014 6:12 pm
Anyone got any ideas ?
matt horton
Re: help
Postby Wack » Wed Jul 16, 2014 6:24 pm
Are you sure they are proper Lambretta points as some Vespa ones fit but won't work correctly? Why not clean the old points up to retry and eliminate the new ones as the problem?
Re: help
Postby matt horton » Wed Jul 16, 2014 6:30 pm
Wack wrote:Are you sure they are proper Lambretta points as some Vespa ones fit but won't work correctly? Why not clean the old points up to retry and eliminate the new ones as the problem?
I'll double check but just bought from scooter restorations, I know for cerain the cam heel is identical not sure about base
matt horton
Re: help
Postby Nigel. S » Wed Jul 16, 2014 9:13 pm
I also changed points the other night, from SR.
Turned flywheel until points at their widest opening then set 0.4mm gap. (pretty much as per the book) As you say, not easy to see but laying on the floor with a torch was ok. mine's a 3 slot flywheel. When I stripped mine originally the stator was at the extreme end of slots, from memory I think I moved it back just beyond centre closer to the other extreme of slots when I rebuilt to achieve 19 degs.
Are the original marks yours?
Nigel. S
Re: help
Postby Ivor the engine » Fri Jul 25, 2014 8:55 pm
Hi all,
What ignition do you have, Ducati or Dansi? The Points for these two are different. Ensure you have the correct make for your ignition.
Keep us posted.
Cheers,
Ivor.
Ivor the engine
