Warkton Tornado No.1 wrote:Whoah! Before you start rubbing down…….
The horncasting can be adjusted by virtue of the legshield bracket bolting to the frame. For instance, if you wanted to move the horncasting toward the back of the bike, you need to (obviously) remove it & ‘tweak’ the legshield bracket by bending its ears forwards. It’s amazing what difference it can make to the top end where the horncasting gets close to the headset. Also, paint thicknesses affect the fit so some might need scraping off. I’ve even seen the drastic measure of the legshield bracket being persuaded to be on the other side! Not by me, I might add…
Conversely, washers can pack the legshields/horncasting forward.
I hope this helps…
Kristof Lammy pie wrote:I will take the headset off and see if it can be tweaked slightly.
Cheers guys.
Kris
You'll notice that when I said I used emery cloth to rub the top of the horncast down,I didn't say thats what he should do,just thats what I did.
Warkton Tornado No.1 wrote:You'll notice that when I said I used emery cloth to rub the top of the horncast down,I didn't say thats what he should do,just thats what I did.
You are quite right & in my haste & choice of words it could look like I was implying that you were advocating to do the same. Which, of course you weren't.![]()
My apologies to you Paul, as we are all trying to help, I know.
johnnyXS wrote:nice pairI particularly like the colour scheme on your TV.
So you're a roadie eh !exquisite Tommasini
Users browsing this forum: Captain Pugwash, dickie, Toddy and 0 guests
