Digger wrote:Both wheels should be on the ground when it's on the stand - leave it in gear.
HxPaul wrote:Digger wrote:Both wheels should be on the ground when it's on the stand - leave it in gear.
Why ?
Digger wrote:As Rich said, when they left the factory they all would have both wheels on the ground when on the stand.
As to why - probably so you can move it around with relative ease when it is on the stand. It's a lot easier putting a Lambretta in the corner of a shed or garage without wacking the rear light against the wall when you can move it around with the stand is down.
burnside wrote:Front wheel 'touches' the ground on all of mine but only just and no weight on the front wheel. One of my pet hates seeing Scooters parked up with the front wheel several inches of the ground, just looks wrong
burnside wrote:
Stainless stands are notorious for being too long so front wheel sits up in the air, how hard can it be to make them the same length as original?
Users browsing this forum: No registered users and 47 guests
