series 1 drive assembly spring
Postby peejay » Thu Jul 10, 2014 4:00 pm
hi peeps
could someone tell me the length of this (missing) item for a mate's engine rebuild, ta :)
Re: series 1 drive assembly spring
Postby Wack » Thu Jul 10, 2014 6:03 pm
I seem to remember they're 8-10mm shorter than a Ser 3. Why not use a Ser 3 one with the Ser 1 top cap? It's harder to fit but stops the ramps jumping ;)
Postby petemaisey » Thu Jul 10, 2014 8:49 pm
If you upgrade to the taller spring you will also need the deeper crankcase cover.
Pete
petemaisey
Postby peejay » Thu Jul 10, 2014 8:59 pm
thanks guys for the replies.
my mate would like to keep it as original if possible so was curious as to the different length needed as we only have series 3 to hand
Postby HxPaul » Fri Jul 11, 2014 9:03 am
petemaisey wrote:If you upgrade to the taller spring you will also need the deeper crankcase cover.
Pete
Fitting a longer spring wont make any difference to the length of the drive assembly,the spring will be compressed more making it stiffer.
Postby waddo » Fri Jul 11, 2014 11:12 am
peejay wrote:thanks guys for the replies.
Hi i have a Series 1 engine i am breaking for spares. i have the parts you need, but i am away on holiday from today, only the lads at home, who dont do Lambrettas, If you still need the parts after the 19th, contact me and i can help you out. Hope this helps.
Waddo.
waddo
Postby peejay » Fri Jul 11, 2014 6:29 pm
hi Waddo
thanks for that, i'll let my mate know :)
Postby davej » Mon Jul 14, 2014 5:55 pm
I am the person looking at this Series 1 engine at present, The situation I have is that the original Spring has a length of 29mm and when re fitting the Top Cap starts to engage on the splines and tightens up very quickly which means the Spring can be rotated very easy. Am I correct in thinking that I should have more compression on the Spring similar to a Series 3 engine, Any guidance would be appreciated. Thanks
davej
Postby Scooter Paul » Tue Jul 15, 2014 11:40 am
davej wrote:I am the person looking at this Series 1 engine at present, The situation I have is that the original Spring has a length of 29mm and when re fitting the Top Cap starts to engage on the splines and tightens up very quickly which means the Spring can be rotated very easy. Am I correct in thinking that I should have more compression on the Spring similar to a Series 3 engine, Any guidance would be appreciated. Thanks
These are the symptoms of a series one spring being incorrectly fitted to a later set up. Possibly a mixture of early and later parts? On the face of it a series three type spring would be better. You shouldn't be able to twist the spring once properly tightened down. If you buy a new Indian spring you may have to lightly Dremmel the inside of the spring to get the top hat to sit in it but no dramas otherwise.
Scooter Paul
Postby davej » Wed Jul 16, 2014 11:05 pm
Thanks Scooter Paul, Following your advice of fitting a Series 3 Spring should I use a Series 3 Top Hat as well?
davej
