CHRIS in MARGATE wrote:Take out the brown wire that comes from the main loom and connects to the regulator. May also be connected with a purple wire. Attach the positive clip of a battery charger through a 10 amp fuse in a fuse holder (about £1.50) at Halfords or The Range. Connect the negative wire of the battery charger to a good earth.
This is your live feed to the headset without the engine running.
Put the black lead of your new multimeter to a good earth and then measure on a range close to about 20 volts Volts AC and satisfy yourself with regard to the voltage at the back end of the scooter on your connected positive lead.
Now look for this voltage at the headlamp connector and work back.
Make sure the headlamp bulb connector assembly has a good earth.
I wish I was there because I could do this for you in no time.
jonoy wrote:there are 2 wires going into this
