Intermittent lights
Re: Intermittent lights
Postby CHRIS in MARGATE » Sat Nov 14, 2015 12:07 pm
Colours ? Where do they appear to go ?
Postby coaster » Sat Nov 14, 2015 12:37 pm
CHRIS in MARGATE wrote:Take out the brown wire that comes from the main loom and connects to the regulator. May also be connected with a purple wire. Attach the positive clip of a battery charger through a 10 amp fuse in a fuse holder (about £1.50) at Halfords or The Range. Connect the negative wire of the battery charger to a good earth.
This is your live feed to the headset without the engine running.
Put the black lead of your new multimeter to a good earth and then measure on a range close to about 20 volts Volts AC and satisfy yourself with regard to the voltage at the back end of the scooter on your connected positive lead.
Now look for this voltage at the headlamp connector and work back.
Make sure the headlamp bulb connector assembly has a good earth.
I wish I was there because I could do this for you in no time.
Brilliant advice but using a battery charger as a power source, you will need to set the meter to DC volts not AC ;)
Also, I would not recommend the red crimp bullet terminals as they are too small and will work loose and cause problems in the future. Send a PM Knowledge on here, he sells kits and loose connectors which are the correct size.
Also, if you want to check that a connector is performing as it should, put one lead of the meter (set to volts) immediately before and after the connection. If all is well the reading will be zero but if there is any reading at all then you have resistance and therefore volts drop due tyo a poor connection,
Postby Captain Pugwash » Sat Nov 14, 2015 1:49 pm
jonoy wrote:there are 2 wires going into this
If you only have two wires at the junction box then I don't think you have a standard loom.
Captain Pugwash
Postby CHRIS in MARGATE » Sat Nov 14, 2015 2:37 pm
I may be half wrong about the charger output because the DC voltage is rectified AC. Anyway try either lol !
I found the red bullets to be fine but appreciate that where age has worn down terminal blocks then they might not be tight but then again once the tension has been lost on old terminal blocks, most connectors struggle to make an excellent contact.
With electrical connections don't settle for "that'll do" because invariably you'll end up chasing more than one fault. Best connection you can make is what is needed at every point.
Postby jonoy » Sat Nov 14, 2015 4:56 pm
Well I managed to give my self a shock
With the headset wiring twiddling with
Block so power is getting up there
jonoy
Postby Meds » Sat Nov 14, 2015 5:35 pm
Are you getting anywhere yet
Meds
Postby jonoy » Sat Nov 14, 2015 5:37 pm
Yes my hairs standing up
Will a trickle charger be enough to provide power
jonoy
Postby Meds » Sat Nov 14, 2015 5:38 pm
Should be
Do yo have an I pad, I'm about to do some work on mine so we could try using face time and I will run through it with you
Meds
Postby Captain Pugwash » Sat Nov 14, 2015 5:46 pm
Be careful when your checking the wires when you have a live feed to the headset, if you happen to touch the green wires in the headlight junction box with a live 12v DC feed you can blow the two diodes in the electronic pickup that's fitted to the stator instantly.
Captain Pugwash
Postby jonoy » Sat Nov 14, 2015 6:12 pm
I am leaving it tonight came in straight from work and started to work on it
I will need to get a spade end connector to Attach to battery charger so I coolected to scooter
I resoldered the blue wire that connects into back of block as this looked suspect but no joy
jonoy
Postby jonoy » Sat Nov 14, 2015 8:39 pm
I have a purple goin into orange at back of block
2 orange going into grey
Casa ac loom
jonoy
Postby jonoy » Fri Nov 20, 2015 10:15 pm
Thank you for your help
I bought a new block from scootopia and some new bullet connectors recrimped the dodgy ones and lights now fine
jonoy
Postby jonoy » Mon Nov 23, 2015 9:14 pm
Update fitted it all back together last night
Thought I'd give it a run today just to make sure of lights
When I started the bike everything worked even the pilot light for the first time.
Then everything started to flicker and then nothing not even brake light or hooter.
Eventually everything started to work as it should but still not 100 %
jonoy
Postby wellerchap » Mon Apr 04, 2016 8:47 pm
Hi Jonoy - did you get to the bottom of this issue eventually?
wellerchap
Postby jonoy » Mon Apr 04, 2016 10:24 pm
Yes bought a new block and brass connectors my partner soldered
them on and then shrink wrapped them
jonoy
Postby wellerchap » Tue Apr 19, 2016 3:42 pm
Good stuff - all's well that ends well.
wellerchap
Users browsing this forum: Baidu [Spider] and 16 guests
