6V to 12v
6V to 12v
Postby Geocamper » Fri Jul 04, 2014 3:39 pm
Could send one please direct me in the right direction as regards to the best components to change my TV175 series 2 from 6v to 12v. It's bit of a minefield out there for a newbie to Lambretta's. Looking a the cost also. I don't mind paying for quailty part. Thanks
Geocamper
Re: 6V to 12v
Postby Scooterlam » Fri Jul 04, 2014 10:43 pm
You have a choice of 12v with points or electrictronic. What do you want to improve.
Scooterlam
Re: 6V to 12v
Postby grandpa » Sat Jul 05, 2014 4:19 pm
Hi,
I used 12volt stator coils that were available from ebay (keeping the points for easy maintenance) but scoot rs sell the coils or complete 12volt stators.If used with the wassell D.C conversion and 5amp/hr battery you will have good lights and a horn that works.You will need a 12 dc horn if you go down this route. Google lambretta 12 volt dc conversion and also have a look at the scooterotica site.The old LCGB forum had many posts on the subject perhaps one of the pioneers of the wassell conversion i.e soulsurfer, mkmonty,coaster, firedkp et al can post some pics or wiring diagrams that they hold on their computers and could upload to rebuild the data base
Grandpa
grandpa
Re: 6V to 12v
Postby Geocamper » Sat Jul 05, 2014 5:23 pm
Thanks for your replies guys. I'm basically looking to uprate the lights and horn. I would like to keep everything else nice and simple.
Geocamper
Re: 6V to 12v
Postby Captain Pugwash » Sat Jul 05, 2014 6:11 pm
Geocamper wrote:Could send one please direct me in the right direction as regards to the best components to change my TV175 series 2 from 6v to 12v. It's bit of a minefield out there for a newbie to Lambretta's. Looking a the cost also. I don't mind paying for quailty part. Thanks
The TV 2 is still running a four pole stator and flywheel ?
Captain Pugwash
Re: 6V to 12v
Postby Scooterlam » Sat Jul 05, 2014 10:54 pm
Tere used to be a way to do it on the old site,
basically you take the two yellows join them together and put it thru a regulator.
Ive run this on a bike with no problems.
Scooterlam
Re: 6V to 12v
Postby Captain Pugwash » Sun Jul 06, 2014 10:05 am
Scooterlam wrote:Tere used to be a way to do it on the old site,
With a standard TV 2 stator ?
Captain Pugwash
Re: 6V to 12v
Postby Geocamper » Sun Jul 06, 2014 8:07 pm
I believe so. Everything is standard 6v.
Geocamper
Re: 6V to 12v
Postby Captain Pugwash » Sun Jul 06, 2014 8:27 pm
Your probably better fitting a replacement 6 pole stator and flywheel. You can convert the existing four pole to 12v but there's not the same output as with a 6 pole and I wouldn't think the time and money spent converting the 4 pole would be worth it.
You could fit a second hand 6 pole points condenser stator from a later Italian series 3 TV SX or LI and have it converted to 12 volt or you could buy a complete new electronic 12v stator and flywheel for an LI/SX/TV crank complete with CDI and rectifier.
If I was fitting a complete new electronic setup I would sooner fit a GP type with the longer and much stronger taper but that would mean changing the crank at the same time and that's a complete top end engine strip plus new mag side bearing at the least.
I think the best and cheapest option would be a secondhand later Italian die cast flywheel & stator and have it rewired to 12 volt.
If you do decide to convert a 6v points stator to 12v either dc or ac, then get in touch with me.
Mark.
Captain Pugwash
Re: 6V to 12v
Postby Geocamper » Sun Jul 06, 2014 9:27 pm
Thanks mark for the details you have provided. Sounds like you really know your electrics. I'm sure I'll be intouch as I'm quite a novice as regards to Lambretta's. Cheers
Geocamper
Re: 6V to 12v
Postby Toddy » Mon Jul 07, 2014 6:29 am
Info here
http://scooterotica.org/forum/viewtopic ... conversion" onclick="window.open(this.href);return false;
Re: 6V to 12v
Postby Geocamper » Mon Jul 07, 2014 10:40 am
Thanks Toddy. Appreciated.
Geocamper
Users browsing this forum: Bing [Bot] and 12 guests
